Does anybody know a 100%~software-based way to convert correctly
VSR .wma files into CSR uncompressed audio? Lately I've been forced to record
from the analog output of the sound card and re-digitize the analog recording
in order to avoid loss of audio-video sync.![]()
Results 1 to 18 of 18
Too bad the "pros" keep assuming that variable~sample-rate .WMAs
"do not/cannot exist", so that they can keep ignoring the ASF audio-timecoding
when they design their file-format converters.
This app will convert them to WAV. Dunno if that helps.
http://www.aoamedia.com/audioextractor.htm -
Thanks for the attention, Soopafresh,
but I serious doubt that "AoA AudioExtractor" can do
much more than simply extract a "raw" PCM byte-stream from
a WMA file and happily assume it must be played at a constant sample rate
from the beginning to the end.
I have just tried Mplayer:
As already expectedCode:mplayer -vo directx -ao pcm:file=filename.wav filename.ASF
another application unable to do the job.
HOWEVER, at least it did something funny.
Keep reading, please.
It seems certain software writers are somewhat out-of-touch with reality.[C:\]
=>cd mplayer
[C:\MPlayer]
=>mplayer -vo directx CENSORED.wmv
MPlayer dev-SVN-r25953-4.2.3 (C) 2000-2008 MPlayer Team
CPU: Intel(R) Pentium(R) 4 CPU 1500MHz (Family: 15, Model: 0, Stepping: 10)
CPUflags: MMX: 1 MMX2: 1 3DNow: 0 3DNow2: 0 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
117 audio & 239 video codecs
Playing CENSORED.wmv.
ASF file format detected.
[asfheader] Audio stream found, -aid 1
[asfheader] Video stream found, -vid 2
VIDEO: [WMV3] 854x480 24bpp 1000.000 fps 851.0 kbps (103.9 kbyte/s)
Clip info:
<SNIP>
Opening video decoder: [dmo] DMO video codecs
IMediaObject ERROR: 00E06320 could not open DMO DLL (0x0 : 0)
Failed to create DMO filter
ERROR: Could not open required DirectShow codec wmv9dmod.dll.
You need to upgrade/install the binary codecs package.
Go to http://www.mplayerhq.hu/dload.html
VDecoder init failed
IMediaObject ERROR: 00E064D6 no such class object (0x80004001 : -2147467263)
ERROR: Could not open required DirectShow codec wmvdmod.dll.
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffwmv3] vfm: ffmpeg (FFmpeg WMV3/WMV9)
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 48000 Hz, 2 ch, s16le, 64.0 kbit/4.17% (ratio: 8001->192000)
Selected audio codec: [ffwmav2] afm: ffmpeg (DivX audio v2 (FFmpeg))
AO: [dsound] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 854 x 480 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is undefined - no prescaling applied.
VO: [directx] 854x480 => 854x480 Planar YV12
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
A: 29.5 V: 29.5 A-V: 0.006 ct: -0.043 256/256 2% 36% 0.0% 56 0
**** Your system is too SLOW to play this! ****
Possible reasons, problems, workarounds:
- Most common: broken/buggy _audio_ driver
- Try -ao sdl or use the OSS emulation of ALSA.
- Experiment with different values for -autosync, 30 is a good start.
- Slow video output
- Try a different -vo driver (-vo help for a list) or try -framedrop!
- Slow CPU
- Don't try to play a big DVD/DivX on a slow CPU! Try some of the lavdopts,
e.g. -vfm ffmpeg -lavdopts lowres=1:fast
kiploopfilter=all.
- Broken file
- Try various combinations of -nobps -ni -forceidx -mc 0.
- Slow media (NFS/SMB mounts, DVD, VCD etc)
- Try -cache 8192.
- Are you using -cache to play a non-interleaved AVI file?
- Try -nocache.
Read DOCS/HTML/en/video.html for tuning/speedup tips.
If none of this helps you, read DOCS/HTML/en/bugreports.html.
( etc. etc. etc. )
At last... ... ...
1) add the fukking wma to the playlist of WinAmp;
2) goto Icon Menu, Options, Preferences, Plug-ins, Output,
NullSoft Disk Writer; configure, OK, close;
3) Click the Play button;
4) Voilą!
5) Windows Media Audio sucks, Windows Movie Maker sucks,
Windows Media Encoder sucks, Bill Gates is a very sexy man.
[ UPDATE ]
I have just found another workaround:
use WMVMuxer for converting the lossy WMA streams into lossless WMA files
these latter do not have the infamous variable sample-rate thing, and thus
they can be re-encoded to a non-M§ lossy format without synchronization issues.
[s:8e5a396f16]This method is superior to the use of Winamp's Disk Writer plugin because
it's able to produce a CSR multichannel output.[/s:8e5a396f16]
[EDIT]
Now I have to correct myself.
Because WMVmuxer can convert lossy stereo WMA to Lossless stereo WMA, I happily assumed it was able to do the same to
*multichannel* audio. Not true, sadly. Yes, WMNicEnc is capable of encoding to
multichannel Windows Media Audio, however there are no guarantees that the outputs
created in this way will always be "100% OK".
For the curious, here goes the .prx file I used upon a
common stereo WMA track sampled @ 48kHz: <-- ( This one works for me
<profile version="589824"
storageformat="1"
name="WMA-old-To-WMA-lossless"
description="">
<streamconfig majortype="{73647561-0000-0010-8000-00AA00389B71}"
streamnumber="1"
streamname="Audio Stream"
inputname="Audio409"
bitrate="128016"
bufferwindow="-1"
reliabletransport="0"
decodercomplexity=""
rfc1766langid="en-us"
vbrenabled="1"
vbrquality="100"
bitratemax="0"
bufferwindowmax="0">
<wmmediatype subtype="{00000163-0000-0010-8000-00AA00389B71}"
bfixedsizesamples="1"
btemporalcompression="0"
lsamplesize="12288">
<waveformatex wFormatTag="355"
nChannels="2"
nSamplesPerSec="48000"
nAvgBytesPerSec="2147483492"
nBlockAlign="12288"
wBitsPerSample="24"
codecdata="1800030000000000000000000000A1010000"/>
</wmmediatype>
</streamconfig>
</profile> -
Well, to say "record what we hear" may be somewhat misleading.Originally Posted by jagabo
IF the recording software emulates an analog audio capture, then it will work,
otherwise it won't --- it's pointless to get the uncompressed bitstream from a
WMA track without honoring the timestamps in the ASF container.
I had already tried both Goldwave and Total Recorder, and they both failed ---
--- not much different from Avisynth's DirectShowSource. -
"What you hear" is the final output pin of the system mixer -- just before audio goes to the sound card. Some cards/drivers call this "Stereo Mix" or some other name. I believe it's always at a fixed sample rate (ie, the mixer can take several inputs at several different sample rates from several programs, and convert them all to one fixed rate before sending to the audio card). Just don't do other stuff while recording or all your system sounds (clicks, beeps, boops, new mail, etc) will be recorded too.Originally Posted by Midzuki
Can you point to, or upload, some sample files? -
I will PM you, then.
Currently I am on a dial-up connection,
which makes the file transfers above 20MB quite unpractical.
How to change sample rate in FFMPEG
By MackanZoor in forum AudioReplies: 5Last Post: 24th Jan 2011, 13:31 -
Yet Another Sample-Rate-Conversion Tool
By El Heggunte in forum AudioReplies: 2Last Post: 11th Dec 2009, 19:57 -
Sample Rate Differences?!
By GangstaRap in forum Video ConversionReplies: 1Last Post: 27th Dec 2007, 05:28 -
DVD Audio To .wav Sample Rate Question
By xtreme469 in forum AudioReplies: 3Last Post: 29th Sep 2007, 09:04 -
inconsistent audio sample rate error in FCE...
By ednarophati in forum MacReplies: 1Last Post: 23rd Aug 2007, 13:59
